The impulses produced by sensory nerve endings, Journal of Physiology, vol.61, issue.1, pp.49-72, 1926. ,
Arithmetic coding revealed: A guided tour from theory to praxis, 2007. ,
Nature is the code: High reproducibility in v1 and a model of optimal dissipation of visual structural complexity ,
Reading a neural code, Science, vol.252, issue.5014, pp.1854-1857, 1991. ,
Text compression, 1990. ,
Finite Elements on Dyadic Grids with Applications, Applied and Computational Mathematics -Selected Papers of the Fifth PanAmerican Workshop, pp.1-4, 2004. ,
DOI : 10.1016/j.matcom.2006.06.024
Self-organizing maps with dynamic learning for signal reconstruction, Neural Networks, vol.20, issue.2, pp.274-284, 2007. ,
DOI : 10.1016/j.neunet.2006.12.002
The JPEG2000 still image coding system: an overview, IEEE Transactions on Consumer Electronics, vol.46, issue.4, pp.1103-1127, 2000. ,
DOI : 10.1109/30.920468
Real-time performance of a movement-sensitive neuron in the blowfly visual system: Coding and information transfer in short spike sequences, Proceedings of the Royal Society of London. Series B. Biological Sciences, pp.379-414, 1277. ,
What is the goal of sensory coding?, Neural Computation, vol.6, issue.4, pp.559-601, 1994. ,
Vector Quantization and Signal Compression , volume 159 of The Springer International Series in Engineering and Computer Science, 1992. ,
What's wrong with mean-squared error?, digital images and human vision, pp.207-220, 1993. ,
Rapid Neural Coding in the Retina with Relative Spike Latencies, Science, vol.319, issue.5866, pp.3191108-1111, 2008. ,
DOI : 10.1126/science.1149639
Rate coding versus temporal order coding: a theoretical approach, Biosystems, vol.48, issue.1-3, pp.57-65, 1998. ,
DOI : 10.1016/S0303-2647(98)00050-1
Cat retinal ganglion cells: size and shape of receptive field centres, The Journal of Physiology, vol.242, issue.1, pp.99-118, 1974. ,
Comparing measures of sparsity (submitted), 2008. ,
An introduction to arithmetic coding, IBM J. RES. DEVELOP, 1984. ,
Measuring sparseness of noisy signals, Proceedings of 4th International Symposium on Independent Component Analysis and Blind Signal Separation, pp.125-130, 2003. ,
The self-organizing map, Neurocomputing, vol.21, issue.1- 3, pp.1-6, 1998. ,
Receptive fields of primate retinal ganglion cells studied with a novel technique, Visual Neuroscience, vol.15, issue.1, pp.161-175, 1998. ,
DOI : 10.1017/S095252389815112X
Encoding of Natural Scene Movies by Tonic and Burst Spikes in the Lateral Geniculate Nucleus, Journal of Neuroscience, vol.24, issue.47, pp.10731-10740, 2004. ,
DOI : 10.1523/JNEUROSCI.3059-04.2004
Statistically and perceptually motivated nonlinear image representation, Human Vision and Electronic Imaging XII, 2007. ,
DOI : 10.1117/12.720848
A theory for multiresolution signal decomposition : the wavelet representation, IEEE transactions on pattern analysis and machine intelligence, vol.11, issue.7, pp.674-693, 1989. ,
The Neural Code of the Retina, Neuron, vol.22, issue.3, pp.435-450, 1999. ,
DOI : 10.1016/S0896-6273(00)80700-X
Neural Data Compression with Wavelet Transform: A Vocabulary Based Approach, 2007 3rd International IEEE/EMBS Conference on Neural Engineering, pp.666-669, 2007. ,
DOI : 10.1109/CNE.2007.369760
INRIA Spike based neural codes : towards a novel bio-inspired still image coding schema43 Emergence of simple-cell receptive-field properties by learning a sparse code for natural images, Nature, issue.6583, pp.381607-609, 1996. ,
Time course of neural responses discriminating different views of the face and head, Journal of Neurophysiology, vol.68, issue.1, pp.70-84, 1992. ,
Learning sparse image codes using a wavelet pyramid architecture, Advances in Neural Information Processing Systems, pp.887-893, 2001. ,
Neural coding, Neurosciences Research Program Bulletin, vol.6, pp.221-343, 1968. ,
Comment dchiffrer le code impulsionnel de la Vision? tude du flux parallle, asynchrone et pars dans le traitement visuel ultra-rapide, 2003. ,
Compression of Spike Data Using the Self-Organizing Map, Conference Proceedings. 2nd International IEEE EMBS Conference on Neural Engineering, 2005., pp.233-236, 2005. ,
DOI : 10.1109/CNE.2005.1419599
Coding Static Natural Images Using Spiking Event Times: Do Neurons Cooperate?, IEEE Transactions on Neural Networks, vol.15, issue.5, pp.1164-1175, 2004. ,
DOI : 10.1109/TNN.2004.833303
URL : https://hal.archives-ouvertes.fr/hal-00110803
Quantitative analysis of the cat retinal ganglion cells response to visual stimuli, Vision Research, vol.5, issue.11, pp.583-601, 1965. ,
A Novel Weighted LBG Algorithm for Neural Spike Compression, 2007 International Joint Conference on Neural Networks, pp.1883-1887, 2007. ,
DOI : 10.1109/IJCNN.2007.4371245
Rate Coding Versus Temporal Order Coding: What the Retinal Ganglion Cells Tell the Visual Cortex, Neural Computation, vol.78, issue.6, pp.1255-1283, 2001. ,
DOI : 10.1016/0042-6989(96)00098-3
Surfing a spike wave down the ventral stream, Vision Research, vol.42, issue.23, pp.2593-2615, 2002. ,
DOI : 10.1016/S0042-6989(02)00298-5
Spikes: Exploring the Neural Code, 1997. ,
Introduction to Data Compression, Series in Multimedia Information and Systems, 2000. ,
JPEG2000: The upcoming still image compression standard, Pattern Recognition Letters, vol.22, issue.12, pp.1337-1345, 2001. ,
DOI : 10.1016/S0167-8655(01)00079-4
The steerable pyramid: a flexible architecture for multi-scale derivative computation, Proceedings., International Conference on Image Processing, pp.444-447, 1995. ,
DOI : 10.1109/ICIP.1995.537667
Maximising information recovery from rank-order codes, Proceedings of SPIE conference on Data Mining, Intrusion Detection, Information Assurance, and Data Networks Security, p.65700, 2007. ,
Reconstruction of natural scenes from ensemble responses in the lateral geniculate nucleus, Journal of Neuroscience, vol.19, issue.18, pp.8036-8042, 1999. ,
Speed of processing in the human visual system, Nature, vol.381, issue.6582, pp.520-522, 1996. ,
DOI : 10.1038/381520a0
Spike arrival times: A highly efficient coding scheme for neural networks. Parallel processing in neural systems and computers, pp.91-94, 1990. ,
Stack-run image coding, IEEE transactions on circuits and systems for video technology, pp.519-521, 1996. ,
DOI : 10.1109/76.538934
The dynamics of the cat x cell center, Journal of physiology, vol.386, pp.219-246, 1987. ,
Directly invertible nonlinear divisive normalization pyramid for image representation . Visual Content Processing and Representation, pp.331-340, 2003. ,
Is it a Bird? Is it a Plane? Ultra-Rapid Visual Categorisation of Natural and Artifactual Objects, Perception, vol.11, issue.6, pp.655-668, 2001. ,
DOI : 10.1068/p3029
Image Quality Assessment: From Error Visibility to Structural Similarity, IEEE Transactions on Image Processing, vol.13, issue.4, pp.600-612, 2004. ,
DOI : 10.1109/TIP.2003.819861
Virtual Retina: A biological retina model and simulator, with contrast gain control, Journal of Computational Neuroscience, vol.32, issue.3, pp.219-249, 2009. ,
DOI : 10.1007/s10827-008-0108-4
URL : https://hal.archives-ouvertes.fr/inria-00160716
Retinal filtering and image reconstruction, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00394547
Spiking Neuron Models : Single Neurons, Populations, Plasticity, 2002. ,
DOI : 10.1017/CBO9780511815706
13 2.2.1 From actual cell recordings, 13 2.2.2 From simulated retina models outputs . . . . . . . . . . . 16 ,
22 3.3.1 The Thorpe retina bricks, Image reconstruction, p.26 ,
