The Art of the Metaobject Protocol, 1991. ,
Aspect-oriented programming, Proceedings of the 11th European Conference on Object-Oriented Programming, pp.220-242, 1997. ,
DOI : 10.1007/BFb0053381
An Overview of AspectJ, Proceedings of the 15th European Conference on Object- Oriented Programming, pp.327-353, 2001. ,
DOI : 10.1007/3-540-45337-7_18
Memory coherence in shared virtual memory systems, ACM Transactions on Computer Systems, vol.7, issue.4, pp.321-359, 1989. ,
DOI : 10.1145/75104.75105
« Assemblage de composants et programmation par aspects ,
« On the criteria to be used in decomposing systems into modules, Communications of the ACM, vol.15, issue.12, pp.1053-1058, 1972. ,
A Flexible Solution for Aspect-Oriented Programming in Java, Proceedings of Reflection'01, pp.1-24, 2001. ,
« An UML notation for aspect-oriented software design, 2002. ,
Répartie Partagée sur CHORUS : de l'implantation de la cohérence causale vers un mappeur générique, 1997. ,
