Monitoring and Controlling Content Access in KAD - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new distributed architecture that aims to investigate and control the spread of contents in the KAD P2P network through the indexation of keywords and files. Our solution can control the DHT at a local level with a new strategy bypassing the Sybil attack protections inserted in KAD. For the targeted DHT entries, we can monitor all requests emitted by the peers, from the initial content publication or search, to the final download request of fake files, assessing accurately peers interest to access it. We demonstrate the efficiency of our approach through experiments performed on the worldwide KAD network.
ICC10-Monitoring_KAD_Contents-Cholez.pdf (366.84 Ko) Télécharger le fichier
ICC10_Poster-Monitoring_KAD_Contents-Cholez.pdf (704.66 Ko) Télécharger le fichier
Format : Autre
inria-00490347 , version 1 (08-06-2010)
  • HAL Id : inria-00490347 , version 1
Thibault Cholez, Isabelle Chrisment, Olivier Festor. Monitoring and Controlling Content Access in KAD. International Conference on Communications - ICC 2010, IEEE, May 2010, Capetown, South Africa. ⟨inria-00490347⟩
165 Consultations
316 Téléchargements
