Hiding Design-Decisions in Service-Oriented Software via Service Abstraction Recovery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
In this paper, we propose an approach for the recovery of service abstractions out of sets of available services that play the role of alternative design-decisions, which can be used in a service-oriented application. A service abstraction provides a uniform interface that hides dierences in the interfaces of alternative services and consequently allows reducing the coupling between the application and the services. To this end, we formally define the notion of service abstraction and propose a hierarchical clustering algorithm that incrementally recovers a hierarchy of service abstractions out of a given set of alternative design-decisions/services. Finally, we evaluate the proposed algorithm with real-world sets of services and report on our findings.
AbstractionRecoveryHal.pdf (673.07 Ko) Télécharger le fichier
inria-00491349 , version 1 (11-06-2010)
inria-00491349 , version 2 (14-06-2010)
  • HAL Id : inria-00491349 , version 2
Dionysis Athanasopoulos, Apostolos Zarras, Valérie Issarny, Panos Vassiliadis. Hiding Design-Decisions in Service-Oriented Software via Service Abstraction Recovery. [Research Report] 2010. ⟨inria-00491349v2⟩
Collections
INRIA INRIA2 LARA
104 Consultations
103 Téléchargements
