Hiding Design-Decisions in Service-Oriented Software via Service Abstraction Recovery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
In this paper, we propose an approach for the recovery of service abstractions out of sets of available services that play the role of alternative design-decisions, which can be used in a service-oriented application. A service abstraction pro- vides a uniform interface that hides dierences in the inter- faces of alternative services and consequently allows reduc- ing the coupling between the application and the services. To this end, we formally define the notion of service abstrac- tion and propose a hierarchical clustering algorithm that in- crementally recovers a hierarchy of service abstractions out of a given set of alternative design-decisions/services. Fi- nally, we evaluate the proposed algorithm with real-world sets of services and report on our findings.
fse10vSUBMITTED.pdf (684.35 Ko) Télécharger le fichier
inria-00491349 , version 1 (11-06-2010)
inria-00491349 , version 2 (14-06-2010)
  • HAL Id : inria-00491349 , version 1
Dionysis Athanasopoulos, Apostolos Zarras, Valérie Issarny, Panos Vassiliadis. Hiding Design-Decisions in Service-Oriented Software via Service Abstraction Recovery. [Research Report] 2010. ⟨inria-00491349v1⟩
104 Consultations
103 Téléchargements
