DHT-based distributed ALE engine in RFID Middleware
Abstract : Following the “Internet of Things” concept, each object is associated with a unique identifier which will allow to retrieve information about it in large databases. In the process of managing a large amount of objects, and consequently a large amount of events from readers, without overloading the network, these events have to be filtered and aggregated. This is the aim of the Application Level Events (ALE) standard from EPCGlobal, which receives events from readers and sends a useful and well constructed report to the business application. The ALE may be connected to several hundreds of readers. As the number of readers may increase with the increase of the company, a bottleneck may appear with all readers events sent to the ALE. A solution for scalability is to distribute the ALE. In this research report, we propose an efficient way to solve this problem based on a Distributed Hash table (DHT). One role of the ALE is to insulate business application from technical concern so in our solution, we present a mechanism to distribute the ALE using Chord, a well-known peer-to-peer lookup system, and being transparent for business application. This solution is compliant with the EPCglobal existing standard, scalable, robust and transparent for other layers of the middleware. We show that the overhead generated by our solution is of 10% only in a nominal case.
Type de document :
Rapport
[Research Report] RR-7316, INRIA. 2010, pp.22
Liste complète des métadonnées
Littérature citée [13 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00491795
Contributeur : Loïc Schmidt <>
Soumis le : vendredi 18 juin 2010 - 16:09:45
Dernière modification le : samedi 16 juin 2018 - 22:46:02
Document(s) archivé(s) le : lundi 20 septembre 2010 - 17:32:58
Fichier
RR-7316.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00491795, version 2
Collections
Citation
Loïc Schmidt, Roudy Dagher, Roberto Quilez, Nathalie Mitton, David Simplot-Ryl. DHT-based distributed ALE engine in RFID Middleware. [Research Report] RR-7316, INRIA. 2010, pp.22. 〈inria-00491795v2〉
Métriques
Consultations de la notice
338
Téléchargements de fichiers
214
