Snap-Stabilizing Linear Message Forwarding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2010
In this paper, we present the first snap-stabilizing message forwarding protocol that uses a number of buffers per node being inde- pendent of any global parameter, that is 4 buffers per link. The protocol works on a linear chain of nodes, that is possibly an overlay on a large- scale and dynamic system, e.g., Peer-to-Peer systems, Grids. . . Provided that the topology remains a linear chain and that nodes join and leave “neatly”, the protocol tolerates topology changes. We expect that this protocol will be the base to get similar results on more general topologies.
TechReport.pdf (380.45 Ko) Télécharger le fichier
inria-00492870 , version 1 (17-06-2010)
  • HAL Id : inria-00492870 , version 1
  • ARXIV : 1006.3432
Anissa Lamani, Alain Cournier, Swan Dubois, Franck Petit, Vincent Villain. Snap-Stabilizing Linear Message Forwarding. [Technical Report] ???. 2010. ⟨inria-00492870⟩
156 Consultations
151 Téléchargements
