Dynamo, ACM SIGPLAN Notices, vol.35, issue.5, pp.1-12, 2000. ,
DOI : 10.1145/358438.349303
Dynamo: a transparent dynamic optimization system, Proceedings of the ACM SIGPLAN 2000 Conference on Programming Language Design and Implementation (PLDI), pp.1-12, 2000. ,
IA-32 execution layer: a two-phase dynamic translator designed to support IA-32 applications on Itanium/spl reg/-based systems, 22nd Digital Avionics Systems Conference. Proceedings (Cat. No.03CH37449), pp.191-202, 2003. ,
DOI : 10.1109/MICRO.2003.1253195
Digital fx!32 running 32-bit x86 applications on alpha nt, 1997. ,
UQBT: adaptable binary translation at low cost, Computer, vol.33, issue.3, pp.60-66, 2000. ,
DOI : 10.1109/2.825697
The transmeta code morphing TM software: using speculation, recovery, and adaptive retranslation to address real-life challenges, CGO '03: Proceedings of the international symposium on Code generation and optimization, pp.15-24, 2003. ,
Software profiling for hot path prediction: less is more, Proceedings of the 9 th International Conf. on Architectural Support for Programming Languages and Operating Systems, pp.202-211, 2000. ,
Daisy: Dynamic compilation for 100% architectural compatibility, 1996. ,
Daisy: dynamic compilation for 100% architectural compatibility, ISCA '97: Proceedings of the 24th annual international symposium on Computer architecture, pp.26-37, 1997. ,
Optimizations and oracle parallelism with dynamic translation, MICRO 32: Proceedings of the 32nd annual ACM/IEEE international symposium on Microarchitecture, pp.284-295, 1999. ,
Putting the fill unit to work: dynamic optimizations for trace cache microprocessors, Proceedings. 31st Annual ACM/IEEE International Symposium on Microarchitecture, pp.173-181, 1998. ,
DOI : 10.1109/MICRO.1998.742779
Trace-based just-in-time type specialization for dynamic languages, PLDI '09: Proceedings of the 2009 ACM SIGPLAN conference on Programming language design and implementation, pp.465-478, 2009. ,
Incremental dynamic code generation with trace trees ,
Binary translation and architecture convergence issues for IBM system/390, Proceedings of the 14th international conference on Supercomputing , ICS '00, pp.336-347, 2000. ,
DOI : 10.1145/335231.335264
The technology behind Crusoe T M processors. Tansmeta Corporation, 2000. ,
Pin: building customized program analysis tools with dynamic instrumentation, PLDI '05: Proceedings of the 2005 ACM SIGPLAN conference on Programming language design and implementation, pp.190-200, 2005. ,
Compact trace trees in dynamic binary translators, 2 nd workshop on architectural and micro-architectural support for binary translation (AMAS-BT'09), 2009. ,
Trace cache: a low latency approach to high bandwidth instruction fetching, Proceedings of the 29th Annual IEEE/ACM International Symposium on Microarchitecture. MICRO 29, pp.24-35, 1996. ,
DOI : 10.1109/MICRO.1996.566447
Increasing processor performance by implementing deeper pipelines, ACM SIGARCH Computer Architecture News, vol.30, issue.2, pp.25-34, 2002. ,
DOI : 10.1145/545214.545219
A region-based compilation technique for dynamic compilers, ACM Transactions on Programming Languages and Systems, vol.28, issue.1, pp.134-174, 2006. ,
DOI : 10.1145/1111596.1111600
StarDBT: An Efficient Multi-platform Dynamic Binary Translation System, Asia-Pacific Computer Systems Architecture Conference, 2007. ,
DOI : 10.1007/978-3-540-74309-5_3
Phase detection using trace compilation, Proceedings of the 7th International Conference on Principles and Practice of Programming in Java, PPPJ '09, pp.172-181, 2009. ,
DOI : 10.1145/1596655.1596683
YETI, Proceedings of the 3rd international conference on Virtual execution environments , VEE '07, pp.83-93, 2007. ,
DOI : 10.1145/1254810.1254823
