Vulnerability Analysis of L2 Cache Elements to Single Event Upsets, Proceedings of the Design Automation & Test in Europe Conference, pp.3001-1276, 2006. ,
DOI : 10.1109/DATE.2006.244100
Models and Algorithmic Limits for an ECC-Based Approach to Hardening Sub-100-nm SRAMs, Nuclear Science IEEE Transactions on, vol.54, issue.4, pp.935-945 ,
The SimpleScalar tool set, version 2.0, ACM SIGARCH Computer Architecture News, vol.25, issue.3 ,
DOI : 10.1145/268806.268810
Truncated Life Tests in the Exponential Case, The Annals of Mathematical Statistics, vol.25, issue.3, pp.25-28 ,
DOI : 10.1214/aoms/1177728723
Razor: a low-power pipeline based on circuit-level timing speculation, 22nd Digital Avionics Systems Conference. Proceedings (Cat. No.03CH37449), pp.7-18 ,
DOI : 10.1109/MICRO.2003.1253179
Sim-SODA: A Unified Framework for Architectural Level Software Reliability Analysis, Workshop on Modeling, Benchmarking and Simulation ,
Impact of CMOS technology scaling on the atmospheric neutron soft error rate, IEEE Transactions on Nuclear Science, vol.47, issue.6, pp.2586-2594 ,
DOI : 10.1109/23.903813
On-chip cache memory resilience, Proceedings Third IEEE International High-Assurance Systems Engineering Symposium (Cat. No.98EX231), pp.240-247 ,
DOI : 10.1109/HASE.1998.731620
IBM POWER6 processor soft error tolerance analysis using proton irradiation, Proceedings of the 3rd IEEE Workshop on Silicon Errors in Logic. System Effects (SELSE-3) ,
Accurate microarchitecture-level fault modeling for studying hardware faults, 2009 IEEE 15th International Symposium on High Performance Computer Architecture, 2007. ,
DOI : 10.1109/HPCA.2009.4798242
SoftArch: An Architecture Level Tool for Modeling and Analyzing Soft Errors DSN A systematic methodology to calculate the architectural vulnerability factors for a high-performance microprocessor Cache Scrubbing in Microprocessors: Myth or Necessity, Proceedings of the 2005 international Conference on Dependable Systems and Networks Proceedings of the 36th Annual International Symposium on Microarchitecture Proceedings of the 10th IEEE Pacific Rim international Symposium on Dependable Computing (Prdc'04), pp.496-505, 2004. ,
Critical Charge Characterization for Soft Error Rate Modeling in 90nm SRAM Using SimPoint for accurate and efficient simulation, IEEE International Symposium on Circuits and Systems Proceedings of the 2003 ACM SIGMETRICS international Conference on Measurement and Modeling of Calculater Systems SIGMETRICS '03, pp.1879-1882, 2003. ,
An Accurate Analysis of the Effects of Soft Errors in the Instruction and Date Caches of a Pipelined Microprocessor, Proc. of the ACM Europe Conf. and Exhibition (DATE'03), pp.602-607 ,
Determination of key parameters for SEU occurrence using 3-D full cell SRAM simulationsMemory Behavior of the SPEC2000 Benchmark Suite Reliability of Scrubbing Recovery Techniques for Memory Systems International Technology Roadmap for Semiconductors, IEEE Transactions on Nuclear Science IBM Research Report RC IEEE Transactions on Reliability, vol.4639, issue.21852983451, pp.1354-1362, 2000. ,
Reducing Data Cache Susceptibility to Soft Errors, IEEE Transactions on Dependable and Secure Computing, vol.3, issue.4, pp.353-364 ,
DOI : 10.1109/TDSC.2006.55
Techniques to Reduce the Soft Error Rate of a High- Performance Microprocessor, 2004. ,
The Effect of Cosmic Rays on Calculater Memories, Science, vol.206, issue.776 ,
