Parallel Continuation-Passing Style - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christoph M. Angerer
  • Fonction : Auteur
  • PersonId : 872457
Thomas R. Gross
  • Fonction : Auteur
  • PersonId : 872458
We present a parallel version of continuation passing style, called pCPS. Using pCPS as the intermediate representation allows a compiler to first translate a sequential program into a form with explicit scheduling and then gradually increase the parallelism by removing happens-before constraints whenever possible.
PESPMA-angerer.pdf (383.76 Ko) Télécharger le fichier
inria-00494283 , version 1 (22-06-2010)
  • HAL Id : inria-00494283 , version 1
Christoph M. Angerer, Thomas R. Gross. Parallel Continuation-Passing Style. Pespma 2010 - Workshop on Parallel Execution of Sequential Programs on Multi-core Architecture, Jun 2010, Saint Malo, France. ⟨inria-00494283⟩
31 Consultations
352 Téléchargements
