New interface
Reports (Research report)
Chattering-free digital sliding-mode control with state observer and disturbance rejection
Vincent Acary 1 Bernard Brogliato 1 Yury Orlov 2
1 BIPOP - Modelling, Simulation, Control and Optimization of Non-Smooth Dynamical Systems
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : In this paper a novel discrete-time implementation of sliding-mode control systems is proposed, which fully exploits the multivaluedness of the dynamics on the sliding surface. It is shown to guarantee a smooth stabilization on the discrete sliding surface in the disturbance-free case, hence avoiding the chattering effects due to the time-discretization. In addition when a disturbance acts on the system, the controller attenuates the disturbance effects on the sliding surface by a factor h (where h is the sampling period). Most importantly this holds even for large h. The controller is based on an implicit Euler method and is very easy to implement with projections on the interval [-1,1] (or as the solution of a quadratic program). The zero-order-hold (ZOH) method is also investigated. First and second order perturbed systems (with a disturbance satisfying the matching condition) without and with dynamical disturbance compensation are analyzed, with classical and twisted sliding-mode controllers.
Document type :
Complete list of metadata
https://hal.inria.fr/inria-00494417
Contributor : Bernard Brogliato Connect in order to contact the contributor
Submitted on : Friday, July 2, 2010 - 2:57:42 PM
Last modification on : Thursday, October 27, 2022 - 4:02:59 AM
Long-term archiving on: : Thursday, December 1, 2016 - 4:24:13 AM
File
RR-7326.pdf
Identifiers
  • HAL Id : inria-00494417, version 2
Citation
Vincent Acary, Bernard Brogliato, Yury Orlov. Chattering-free digital sliding-mode control with state observer and disturbance rejection. [Research Report] RR-7326, INRIA. 2010. ⟨inria-00494417v2⟩
Share
Metrics
Record views
473
Files downloads
456
