Problèmes d'Optimisation Combinatoire Probabilistes, Ecole National des Ponts et Chaussées, 1993. ,
Average-Case Analysis for the Probabilistic Bin Packing Problem, Trends in Mathematics, pp.149-159, 2004. ,
DOI : 10.1007/978-3-0348-7915-6_15
The Two-Dimensional Probabilistic Bin- Packing Problem : An average case analysis, International journal of mathematics and computer in simulation, pp.42-46, 2008. ,
A Priori Parallel Machines Scheduling Computers & Industrial Engineering, 2010. ,
Probabilistic Combinatorial Optimization problems, 1988. ,
The Probabilistic Minimum Spanning Tree Problem, Networks, pp.245-275, 1990. ,
A Vehicule Routing Problem with Stochastic Demand, Operational Research, pp.574-585, 1992. ,
The Probabilistic Traveling Salesman Problems, Operations Research, 1985. ,
A priori solution of a Travelling Salesman Problem in which a random subset of the customers are visited, Operations research, pp.929-936, 1988. ,
The Traveling Salesman Problem, 1985. ,
Probabilistic graph-coloring in bipartite and split graphs, Journal of Combinatorial Optimization, vol.3, issue.2, 2009. ,
DOI : 10.1007/s10878-007-9112-2
URL : https://hal.archives-ouvertes.fr/hal-00909484
Vertex-Uncertainty in Graph-Problems, Proceedings COCOA'08, pp.139-148, 2008. ,
DOI : 10.1007/978-3-540-85097-7_13
URL : https://hal.archives-ouvertes.fr/hal-00957556
Steiner Forests on Stochastic Metric Graphs, Proceedings COCOA 07, pp.112-123, 2007. ,
DOI : 10.1007/978-3-540-73556-4_14
On the probabilistic minimum coloring and minimum <mml:math altimg="si14.gif" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>k</mml:mi></mml:math>-coloring, Discrete Applied Mathematics, vol.154, issue.3, pp.564-586, 2006. ,
DOI : 10.1016/j.dam.2005.06.007
Paschos, probabilistic combinatorial optimization on graphs, ISTE, 2006. ,
Optimisation combinatoire : concepts avancés, Hermès Science, 2005. ,
The Probabilistic Minimum Coloring Problem, Proceedings WG'03, pp.346-357, 2003. ,
DOI : 10.1007/978-3-540-39890-5_30
The probabilistic maximum independent set problem, Theoretical Computer Science, vol.270, 2002. ,
The Probabilistic Minimum Vertex-covering Problem, International Transactions in Operational Research, vol.9, issue.1, 2002. ,
DOI : 10.1111/1475-3995.00338
The probabilistic longest path problem, Networks, vol.33, 1999. ,
The probabilistic maximum independent set problem, Proceedings ASMDA'95, 1995. ,
Problème du stable probabiliste, Comptes Rendus de l'Académie des Sciences de Paris, t. 321, Série I, 1995. ,
Probabilistic combinatorial optimization problems on graphs: A new domain in operational research, European Journal of Operational Research, vol.87, issue.3, 1995. ,
DOI : 10.1016/0377-2217(95)00240-5
A priori optimization of the probabilistic maximum independent set, ISCIS'98, 1998. ,
