POWER SPECTRUM OF HORIZONTAL WIND SPEED IN THE FREQUENCY RANGE FROM 0.0007 TO 900 CYCLES PER HOUR, Journal of Meteorology, vol.14, issue.2, pp.160-164, 1957. ,
DOI : 10.1175/1520-0469(1957)014<0160:PSOHWS>2.0.CO;2
The appllication of statistical concepts to the wind loading of structures, Proc. Instn. Civ. Engrs, vol.19, pp.449-472, 1961. ,
Frequency Distribution of Wind Speed Near the Surface, Journal of Applied Meteorology, vol.17, issue.11, pp.1633-1642, 1978. ,
DOI : 10.1175/1520-0450(1978)017<1633:FDOWSN>2.0.CO;2
The Characteristics of Wind Velocity that Favor the Fitting of a Weibull Distribution in Wind Speed Analysis, Journal of Climate and Applied Meteorology, vol.23, issue.1, pp.124-134, 1984. ,
DOI : 10.1175/1520-0450(1984)023<0124:TCOWVT>2.0.CO;2
Wind turbine technology, 1994. ,
Electric power from the wind, Federal, pp.9-10, 1945. ,
On the energy output estimation of wind turbines, International Journal of Energy Research, vol.17, issue.1, pp.113-123, 1988. ,
DOI : 10.1002/er.4440120112
Limites du facteur de forme caractérisant le potentiel énergétique d'un site éolien, MOCM, Romanian Technical Sciences Academy, pp.209-214, 2008. ,
La distribution de la plus grande de n valeurs, pp.271-294, 1936. ,
Statistics of extremes, 1958. ,
Design methods for wind loading on class A structures, Wind Engineering in the Eighties, Construc. Ind. Res. Inf. Assoc, 1980. ,
Reliability of a mechanical structure subjected to extreme wind load: a simple analytical approach, Conferinta Ingineria Vântului, pp.311-318, 1998. ,
Fiabilité d'un élément soumis à des contraintes extrêmes, pp.655-656, 1997. ,
Estimation et comparaison des niveaux de retour des vitesses extrêmes des vents, 2004. ,
