Etude des niveaux de contamination chimique en Méditerranée basée sur l'utilisation de stations artificielles de moules, Dubrovnik, vol.35, issue.1, pp.224-225, 1998. ,
Surveillance des niveaux de contamination chimique et radiologique en Méditerranée basée sur l'utilisation de stations artificielles de moules, pp.107-108, 2001. ,
Monitoring chemical contamination levels in the Mediterranean based on the use of mussel caging, Marine Pollution Bulletin, vol.49, issue.9-10, pp.704-712, 2004. ,
DOI : 10.1016/j.marpolbul.2004.05.008
Réseau Intégrateurs Biologiques Evaluation de la qualité des eaux basée sur l'utilisation de stations artificielles de moules en Méditerranée : résultats de la campagne, Rapport IFREMER RST.DOP/LER-PAC, pp.7-24, 2006. ,
Relationships between carbon and cadmium uptake in Mytilus edulis, Marine Biology, vol.22, issue.3, pp.233-244, 1983. ,
DOI : 10.1007/BF00393243
Modelling trace metal (Hg and Pb) bioaccumulation in the Mediterranean mussel, Mytilus galloprovincialis, applied to environmental monitoring, Journal of Sea Research, vol.56, issue.2, pp.168-181, 2006. ,
DOI : 10.1016/j.seares.2006.03.006
RELATION BETWEEN METAL CONCENTRATION IN WATER AND METAL CONTENT OF MARINE MUSSELS (MYTILUS GALLOPROVINCIALIS): IMPACT OF PHYSIOLOGY, Environmental Toxicology and Chemistry, vol.27, issue.7, pp.1543-1552, 2008. ,
DOI : 10.1897/07-418.1
Cadmium in Mytilus spp.: Worldwide survey and relationship between seawater and mussel content, Marine Environmental Research, vol.26, issue.4, pp.265-284, 1988. ,
DOI : 10.1016/0141-1136(88)90352-2
A review of the use of Mytilus spp. As quantitative indicators of cadmium and mercury contamination in coastal water, Oceanol. Acta, vol.12, pp.417-432, 1989. ,
The effect of chelating agents on the uptake and accumulation of cadmium by Mytilus edulis, Marine Biology, vol.21, issue.1, pp.261-268, 1977. ,
DOI : 10.1007/BF00391000
The Mussel Watch, Environmental Conservation, vol.262, issue.02, p.111, 1975. ,
DOI : 10.1016/0025-326X(76)90266-6
