Modelling and control of DC-DC converters, Power Engineering Journal, vol.12, issue.5, pp.229-236, 1998. ,
DOI : 10.1049/pe:19980507
On the practical design of a sliding mode voltage controlled buck converter, IEEE Trans. Power Electron, vol.20, pp.425-437, 2005. ,
Towards applied nonlinear adaptive control, Annual Reviews in Control, vol.32, issue.2, pp.136-148, 2008. ,
DOI : 10.1016/j.arcontrol.2008.08.003
Design and Implementation of an Adaptive Tuning System Based on Desired Phase Margin for Digitally Controlled DC???DC Converters, IEEE Transactions on Power Electronics, vol.24, issue.2, pp.559-564, 2009. ,
DOI : 10.1109/TPEL.2008.2007641
Adaptive Tuning of Switched-Mode Power Supplies Operating in Discontinuous and Continuous Conduction Modes, IEEE Transactions on Power Electronics, vol.24, issue.11, pp.2603-2611, 2009. ,
DOI : 10.1109/TPEL.2009.2029334
Fractional order control strategies for power electronic buck converters, Signal Processing, vol.86, issue.10, pp.2803-2819, 2006. ,
DOI : 10.1016/j.sigpro.2006.02.022
General-purpose fuzzy controller for DC-DC converters, IEEE Transactions on Power Electronics, vol.12, issue.1, pp.79-86, 1997. ,
DOI : 10.1109/63.554172
Adaptive fuzzy logic controller for DC???DC converters, Expert Systems with Applications, vol.36, issue.2, pp.1540-1548, 2009. ,
DOI : 10.1016/j.eswa.2007.11.029
Current sharing of paralleled DC???DC converters using GA-based PID controllers, Expert Systems with Applications, vol.37, issue.1, pp.733-740, 2010. ,
DOI : 10.1016/j.eswa.2009.05.083
Robust control methodologies for dc/dc PWM converters under wide changes in operating conditions, Proc. 6 th WSEAS Internat. Conf. Syst. Theory Scientif. Comput., Elounda, pp.200-210, 2006. ,
Robust tracking with <mml:math altimg="si12.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:msub><mml:mrow><mml:mstyle mathvariant="bold"><mml:mi>H</mml:mi></mml:mstyle></mml:mrow><mml:mrow><mml:mi>???</mml:mi></mml:mrow></mml:msub></mml:math> performance for PWM systems, Automatica, vol.45, issue.8, pp.1808-1818, 2009. ,
DOI : 10.1016/j.automatica.2009.03.026
Robust nonlinear adaptive control of multiphase synchronous buck power converters, Control Engineering Practice, vol.17, issue.11, pp.1245-1254, 2009. ,
DOI : 10.1016/j.conengprac.2009.04.009
URL : https://hal.archives-ouvertes.fr/hal-01058704
Robust Industrial Control Systems Optimal Design Approach for Polynomial Systems, 2006. ,
Commande sans modèle et commandè a modèle restreint, pp.1-23, 2008. ,
MODEL-FREE CONTROL AND INTELLIGENT PID CONTROLLERS: TOWARDS A POSSIBLE TRIVIALIZATION OF NONLINEAR CONTROL?, 15 th IFAC Symp. System Identif., Saint-Malo, 2009. ,
DOI : 10.3182/20090706-3-FR-2004.00256
URL : https://hal.archives-ouvertes.fr/inria-00372325
Flatness and defect of non-linear systems: introductory theory and examples, International Journal of Control, vol.4, issue.6, pp.1327-1361, 1995. ,
DOI : 10.1109/9.73561
Differentially Flat Systems, 2004. ,
A mathematical explanation via " intelligent " PID controllers of the strange ubiquity of PIDs, 18 th Medit. Conf. Control Automation, 2010. ,
Commande sans modèle de vitesse longitudinale d'un véhiculevéhiculé electrique ,
Modelfree control of automotive engine and brake for stop-and-go scenario, 10 th IEEE Conf. Europ. Control Conf, 2009. ,
Model-Free Control of Shape Memory Alloys Antagonistic Actuators, 17 th IFAC World Congress, 2008. ,
DOI : 10.3182/20080706-5-KR-1001.00752
A new control strategy for shape memory alloys actuators, ESOMAT 2009, 8th European Symposium on Martensitic Transformations, 2009. ,
DOI : 10.1051/esomat/200907007
Etude pr??liminaire d'une commande sans mod??le pour papillon de moteur, Journal Europ??en des Syst??mes Automatis??s, vol.42, issue.2-3, pp.337-354, 2008. ,
DOI : 10.3166/jesa.42.337-354
Vers une commande sans modèle pour aménagements hydroélectriques en cascade, Conf. Internat. Francoph. Automat ,
Robust motion control for humanoid robot flexible joints, 18th Mediterranean Conference on Control and Automation, MED'10, 2010. ,
DOI : 10.1109/MED.2010.5547743
Non-linear estimation is easy, International Journal of Modelling, Identification and Control, vol.4, issue.1, pp.12-27, 2008. ,
DOI : 10.1504/IJMIC.2008.020996
URL : https://hal.archives-ouvertes.fr/inria-00158855
Analyse fréquentielle des dérivateurs algébriques, XXII e Coll. GRETSI, Dijon, 2009. ,
Numerical differentiation with annihilators in noisy environment, Numerical Algorithms, vol.14, issue.12, pp.439-467, 2009. ,
DOI : 10.1007/s11075-008-9236-1
URL : https://hal.archives-ouvertes.fr/inria-00319240
Technique de la régulation industrielle, Eyrolles, 1981. ,
Generalized averaging method for power conversion circuits, IEEE Transactions on Power Electronics, vol.6, issue.2, pp.251-259, 1991. ,
DOI : 10.1109/63.76811
Analysis of power electronic converters using the generalized state-space averaging approach, IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, vol.44, issue.8, pp.767-770, 1997. ,
DOI : 10.1109/81.611275
Dynamics of one-cycle controlled Cuk converters, IEEE Transactions on Power Electronics, vol.10, issue.6, pp.634-639, 1995. ,
DOI : 10.1109/63.471282
TOWARDS A MODEL-FREE OUTPUT TRACKING OF SWITCHED NONLINEAR SYSTEMS, th IFAC Symp. Nonlinear Control Systems, 2007. ,
DOI : 10.3182/20070822-3-ZA-2920.00083
URL : https://hal.archives-ouvertes.fr/inria-00147702
