Choosability of the square of planar subcubic graphs with large girth - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics Année : 2009
We show that the choice number of the square of a subcubic graph with maximum average degree less than 18/7 is at most 6. As a corollary, we get that the choice number of the square of a subcubic planar graph with girth at least 9 is at most 6. We then show that the choice number of the square of a subcubic planar graph with girth at least 13 is at most 5.
girth.pdf (175.1 Ko) Télécharger le fichier
inria-00496423 , version 1 (23-10-2016)
  • HAL Id : inria-00496423 , version 1
Frédéric Havet. Choosability of the square of planar subcubic graphs with large girth. Discrete Mathematics, 2009, 309, pp.3553--3563. ⟨inria-00496423⟩
83 Consultations
83 Téléchargements
