Real-time tracking of multiple moving objects using particle filters and probabilistic data association, Automatika, vol.46, issue.12, pp.39-48, 2005. ,
Design and Assessment of an Intelligent Activity Monitoring PlatformAdvances in Intelligent Vision Systems: Methods and Applications, EURASIP Journal on Applied Signal Processing, special issue in, pp.142359-2374, 2005. ,
Tracking and Kalman Filtering Made Easy, 1998. ,
DOI : 10.1002/0471224197
Generation of semantic regions from image sequences, ECCV'96, pp.475-478, 1996. ,
DOI : 10.1007/3-540-61123-1_162
Learning Semantic Scene Models From Observing Activity in Visual Surveillance, IEEE Transactions on Systems, Man and Cybernetics, Part B (Cybernetics), vol.35, issue.3, pp.397-408, 2005. ,
DOI : 10.1109/TSMCB.2005.846652
Efficient particle filtering for multiple target tracking with application to tracking in structured images, Image and Vision Computing, vol.21, issue.10, pp.931-939, 2003. ,
DOI : 10.1016/S0262-8856(03)00087-8
An Efficient and Robust Tracking System using Kalman Filter, VIPSI, 2006. ,
A Movement Tracking Management Model with Kalman Filtering, Global Optimization Techniques and Mahalanobis Distance, Lecture Series on Computer and Computational Sciences, vol.1, pp.1-3, 2005. ,
