Riemannian Median and Its Applications for Orientation Distribution Function Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The geometric median is a classic robust estimator of centrality for data in Euclidean spaces, and it has been generalized in analytical manifold in [1]. Recently, an intrinsic Riemannian framework for Orientation Distribution Function (ODF) was proposed for the calculation in ODF field [2]. In this work, we prove the unique existence of the Riemannian median in ODF space. Then we explore its two potential applications, median filtering and atlas estimation.
Riemannian_Median_for_ODF_ISMRM2010.pdf (842.51 Ko) Télécharger le fichier
inria-00497246 , version 1 (02-07-2010)
  • HAL Id : inria-00497246 , version 1
  • PRODINRA : 247460
Jian Cheng, Aurobrata Ghosh, Tianzi Jiang, Rachid Deriche. Riemannian Median and Its Applications for Orientation Distribution Function Computing. 18th Scientific Meeting and Exhibition of the (ISMRM), 2010, Stockholm, Sweden. ⟨inria-00497246⟩
308 Consultations
128 Téléchargements
