UML 2.2 Superstructure and Infrastructure Modeling and Analysis of Real- time and Embedded systems (MARTE), v1.0, pp.8-14, 2009. ,
A framework for comparing models of computation, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.17, issue.12, pp.1217-1229, 1998. ,
DOI : 10.1109/43.736561
The synchronous languages 12 years later, Proceedings of the IEEE, vol.91, issue.1, pp.64-83, 2003. ,
DOI : 10.1109/JPROC.2002.805826
Modeling Time(s), ACM/IEEE Int. Conf. on Model Driven Engineering Languages and Systems (MoDELS/UML'07), ser. LNCS 4735. TN, pp.559-573, 2007. ,
DOI : 10.1007/978-3-540-75209-7_38
TimeSquare, 2008. ,
Compilation of polychronous data flow equations, " in Correct-by-Construction Embedded Software Synthesis: Formal Frameworks, 2010. ,
Available: http://hal.inria.fr/inria-00384077/en Implementation of the Data-flow Synchronous Language Signal, Syntax and Semantics of the Clock Constraint Specification Language Proceedings of the ACM Symposium on Programming Languages Design and Implementation (PLDI'95, pp.163-173, 1995. ,
On the Semantics of UML/MARTE Clock Constraints, 2009 IEEE International Symposium on Object/Component/Service-Oriented Real-Time Distributed Computing, pp.305-312, 2009. ,
DOI : 10.1109/ISORC.2009.27
URL : https://hal.archives-ouvertes.fr/inria-00383279
Signal and Petri nets, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00283077
A methodological process for the design of a large system, Electronic Notes in Theoretical Computer Science, vol.66, issue.2, pp.84-103, 2002. ,
DOI : 10.1016/S1571-0661(04)80405-5
URL : https://hal.archives-ouvertes.fr/hal-01124776
The Signal Synchronous Multi-Clock Approach to the Design of Distributed Embedded Systems, IEEE Transactions on Parallel and Distributed Systems, vol.99, issue.1, pp.1045-9219, 2009. ,
Validation of mixed signal-alpha real-time systems through affine calculus on clock synchronisation constraints, World Congress on Formal Methods (FM'99), ser. LNCS, pp.1364-1383, 1999. ,
DOI : 10.1007/3-540-48118-4_22
URL : https://hal.archives-ouvertes.fr/hal-00548887
Compositionality in Dataflow Synchronous Languages: Specification and Distributed Code Generation, Information and Computation, vol.163, issue.1, pp.125-171, 2000. ,
DOI : 10.1006/inco.2000.9999
Concurrency in synchronous systems, Formal Methods in System Design, pp.111-130, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00124252
Synthesis of Discrete-Event Controllers based on the Signal Environment, Discrete Event Dynamic System: Theory and Applications, pp.325-346, 2000. ,
URL : https://hal.archives-ouvertes.fr/hal-00546147
