Supporting task-oriented navigation in IDEs with configurable HeatMaps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Mainstream IDEs generally rely on the static structure of a software project to support browsing and navigation. We propose HeatMaps, a simple but highly configurable technique to enrich the way an IDE displays the static structure of a software system with additional kinds of information. A heatmap highlights software artifacts according to various metric values, such as bright red or pale blue, to indicate their potential degree of interest. We present a prototype system that implements heatmaps, and we describe an initial study that assesses the degree to which different heatmaps effectively guide developers in navigating software.
Roet09a-ICPC2009-HeatMaps.pdf (257.39 Ko) Télécharger le fichier
inria-00498454 , version 1 (07-07-2010)
  • HAL Id : inria-00498454 , version 1
David Roethlisberger, Oscar Nierstrasz, Stéphane Ducasse, Damien Pollet, Romain Robbes. Supporting task-oriented navigation in IDEs with configurable HeatMaps. ICPC, May 2009, Vancouver, Canada. ⟨inria-00498454⟩
151 Consultations
183 Téléchargements
