Identifying cycle causes with CycleTable
Identifying and understanding cycles in large applica- tions is a challenging task. In this paper we present Cy- cleTable which displays both direct and indirect references. It shows how minimal cycles are intertwined through shared edges and allows the reengineer to devise simple strategies to remove them.
Langage de programmation [cs.PL]
