Abstract : In this paper we present the first field measurements taken using a new approach proposed in [1] for measuring link impairments in 802.11 WLANs. This uses a sender-side MAC/PHY cross-layer technique that can be implemented on standard hardware and is able to explicitly classify lost transmission opportunities into noise-related losses, collision induced losses, hidden-node losses and to distinguish among these different types of impairments on a per-link basis. We show that potential benefits arising from the availability of accurate and reliable data are considerable.
Douglas J. Leith, David Malone. Field Measurements of 802.11 Collision, Noise and Hidden-Node Loss Rates. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.521-526. ⟨inria-00498508⟩
