Joint Estimation and Gossip Averaging for Sensor Network Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2010
This note presents an efficient distributed approach for computing a spatial average of parameters estimated by sensors in a wireless network. The most intuitive approach would rely on a two-step procedure. First, the nodes would estimate the local quantities, and second a distributed process would average these estimates over the network. Instead, the proposed algorithm combines both processes to foster the convergence while fulfilling the usual wireless sensor network requirements: simplicity, low memory/CPU usage, and asynchronicity.
Fichier non déposé
inria-00499407 , version 1 (09-07-2010)
Nicolas Maréchal, Jean-Benoit Pierrot, Jean-Marie Gorce. Joint Estimation and Gossip Averaging for Sensor Network Applications. IEEE Transactions on Automatic Control, 2010, 55 (5), pp.1208-1213. ⟨10.1109/TAC.2010.2042233⟩. ⟨inria-00499407⟩
193 Consultations
0 Téléchargements
