MULTI-SPECTRAL IMAGE ANALYSIS FOR SKIN PIGMENTATION CLASSIFICATION - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sylvain Prigent
  • Fonction : Auteur
  • PersonId : 872617
Xavier Descombes
Didier Zugaj
  • Fonction : Auteur
Philippe Martel
  • Fonction : Auteur
Josiane Zerubia
  • Fonction : Auteur
  • PersonId : 833424
In this paper, we compare two different approaches for semi- automatic detection of skin hyper-pigmentation on multi- spectral images. These two methods are support vector machine (SVM) and blind source separation. To apply SVM, a dimension reduction method adapted to data classification is proposed. It allows to improve the quality of SVM classification as well as to have reasonable computation time. For the blind source separation approach we show that, using independent component analysis, it is possible to extract a relevant cartography of skin pigmentation.
Article_ICIP.pdf (399.38 Ko) Télécharger le fichier
inria-00499492 , version 1 (09-07-2010)
  • HAL Id : inria-00499492 , version 1
Sylvain Prigent, Xavier Descombes, Didier Zugaj, Philippe Martel, Josiane Zerubia. MULTI-SPECTRAL IMAGE ANALYSIS FOR SKIN PIGMENTATION CLASSIFICATION. IEEE International Conference on Image Processing (ICIP), Sep 2010, Hong Kong, China. ⟨inria-00499492⟩
210 Consultations
706 Téléchargements
