LTE -The UMTS Long Term Evolution: From Theory to Practice, 2009. ,
DOI : 10.1002/9780470978504
The Capacity Region of the Gaussian Multiple-Input Multiple-Output Broadcast Channel, IEEE Transactions on Information Theory, vol.52, issue.9, pp.3936-3964, 2006. ,
DOI : 10.1109/TIT.2006.880064
Linear precoding via conic optimization for fixed MIMO receivers, IEEE Transactions on Signal Processing, vol.54, issue.1, pp.161-176, 2006. ,
DOI : 10.1109/TSP.2005.861073
Linear Processing for the Downlink in Multiuser MIMO Systems with Multiple Data Streams, 2006 IEEE International Conference on Communications, 2006. ,
DOI : 10.1109/ICC.2006.255725
Rate maximization in multi-antenna broadcast channels with linear preprocessing, IEEE Transactions on Wireless Communications, vol.5, issue.9, pp.2338-2342, 2006. ,
DOI : 10.1109/TWC.2006.1687754
Rate optimization for multiuser MIMO systems with linear processing, IEEE Trans. Signal Process, vol.56, issue.8, pp.4020-4030, 2008. ,
Robust Transceiver Optimization in Downlink Multiuser MIMO Systems, IEEE Transactions on Signal Processing, vol.57, issue.9, pp.3576-3587, 2009. ,
DOI : 10.1109/TSP.2009.2020030
Competition Versus Cooperation on the MISO Interference Channel, IEEE Journal on Selected Areas in Communications, vol.26, issue.7, pp.1059-1069, 2008. ,
DOI : 10.1109/JSAC.2008.080904
A framework for uplink power control in cellular radio systems, IEEE Journal on Selected Areas in Communications, vol.13, issue.7, pp.1341-1347, 1995. ,
DOI : 10.1109/49.414651
A Unifying Approach to Interference Modeling for Wireless Networks, IEEE Transactions on Signal Processing, vol.58, issue.6 ,
DOI : 10.1109/TSP.2010.2045415
Spectrum Management for Interference-Limited Multiuser Communication Systems, IEEE Transactions on Information Theory, vol.55, issue.3, pp.1153-1175, 2009. ,
DOI : 10.1109/TIT.2008.2011433
Sum capacity of the vector Gaussian broadcast channel and uplink-downlink duality Solution of the multi-user downlink beamforming problem with individual SINR constraints, IEEE Trans. Inf. Theory IEEE Trans. Veh. Technol, vol.49, issue.53, pp.18-28, 1912. ,
Concave and Convex Interference Functions—General Characterizations and Applications, IEEE Transactions on Signal Processing, vol.56, issue.10, pp.4951-4965, 2008. ,
DOI : 10.1109/TSP.2008.928093
Convex Optimization, 2004. ,
Introduction to Global Optimization, 1995. ,
DOI : 10.1007/978-1-4615-0015-5
Convex Analysis and Global Optimization, 1998. ,
DOI : 10.1007/978-3-319-31484-6
The DC (Difference of Convex Functions) Programming and DCA Revisited with DC Models of Real World Nonconvex Optimization Problems, Annals of Operations Research, vol.6, issue.1, pp.23-46, 2005. ,
DOI : 10.1007/s10479-004-5022-1
Convex optimization II Lecture notes ,
Lectures on Modern Convex Optimization: Analysis, Algorithms, and Engineering Applications, MPS-SIAM Series on Optimization, 2001. ,
DOI : 10.1137/1.9780898718829
Globally Optimal Resource Allocation for Achieving Maximum Weighted Sum Rate, 2010 IEEE Global Telecommunications Conference GLOBECOM 2010 ,
DOI : 10.1109/GLOCOM.2010.5683826
A Superlinearly and Globally Convergent Algorithm for Power Control and Resource Allocation With General Interference Functions, IEEE/ACM Transactions on Networking, vol.16, issue.2, pp.383-395, 2008. ,
DOI : 10.1109/TNET.2007.900362
