Abstract : Power allocation is a promising approach for optimizing the performance of mobile radio systems in interference channels. In the present paper, the non-convex objective function of the power allocation problem aiming at maximizing the sum rate with a total power constraint is reformulated as a difference of two concave functions. A global optimum power allocation is found by applying a branch and bound based algorithm to the new formulation. The algorithm basically splits the feasible region consecutively into subregions where for every subregion the objective function is upper and lower bounded. For a certain partition of the feasible region, a power allocation corresponding to the highest lower bound which is upper bounded by the highest upper bound with some insignificant difference is found as the global optimum. A convex maximization formulation of the optimization problem with a piecewise linearly outer approximated feasible region is essentially applied for finding an upper bound which only requires solving a linear program problem. The simulation results show a significant improvement in the sum rate of the proposed algorithm over the conventional suboptimal techniques.
Type de document :
Communication dans un congrès
WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.367-373, 2010
https://hal.inria.fr/inria-00502221
Contributeur : Service Ist Inria Sophia Antipolis-Méditerranée / I3s
Soumis le : mardi 13 juillet 2010 - 14:51:05
Dernière modification le : mardi 13 juillet 2010 - 15:22:11
Document(s) archivé(s) le : jeudi 14 octobre 2010 - 15:42:10
Hussein Al-Shatri, Tobias Weber. Optimizing Power Allocation in Interference Channels Using D.C. Programming. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.367-373, 2010. 〈inria-00502221〉
