Signing the Unsigned: Robust Surface Reconstruction from Raw Pointsets - Archive ouverte HAL Access content directly
Journal Articles Computer Graphics Forum Year : 2010
Fernando de Goes
  • Function : Author
  • PersonId : 873934
Mathieu Desbrun
David Cohen-Steiner
  • Function : Author
  • PersonId : 833472
Pierre Alliez
We propose a modular framework for robust 3D reconstruction from unorganized, unoriented, noisy, and outlierridden geometric data. We gain robustness and scalability over previous methods through an unsigned distance approximation to the input data followed by a global stochastic signing of the function. An isosurface reconstruction is finally deduced via a sparse linear solve. We show with experiments on large, raw, geometric datasets that this approach is scalable while robust to noise, outliers, and holes. The modularity of our approach facilitates customization of the pipeline components to exploit specific idiosyncracies of datasets, while the simplicity of each component leads to a straightforward implementation.
signing.jpg (15.71 Ko) Télécharger le fichier Fichier principal
signing.pdf (1.51 Mo) Télécharger le fichier
Format : Figure, Image
Origin : Explicit agreement for this submission
Dates and versions
inria-00502473 , version 1 (15-07-2010)
Identifiers
  • HAL Id : inria-00502473 , version 1
Cite
Patrick Mullen, Fernando de Goes, Mathieu Desbrun, David Cohen-Steiner, Pierre Alliez. Signing the Unsigned: Robust Surface Reconstruction from Raw Pointsets. Computer Graphics Forum, 2010, Symposium on Geometry Processing, 29 (5), pp.1733-1741. ⟨inria-00502473⟩
Collections
INRIA INRIA2
455 View
1024 Download
Share
