Surface reconstruction by Voronoi filtering, Discrete & Computational Geometry, vol.22, issue.7, 1999. ,
Voronoi-based variational reconstruction of unoriented point sets, EUROGRAPHICS Symposium on Geometry Processing, pp.39-48, 2007. ,
Multilevel streaming for out-of-core surface reconstruction, EUROGRAPHICS Symposium on Geometry Processing, pp.69-78, 2007. ,
Provably good sampling and meshing of surfaces, Graphical Models, vol.67, issue.5, pp.405-451, 2005. ,
Reconstruction and representation of 3D objects with radial basis functions, SIGGRAPH, pp.67-76, 2001. ,
Geometric Inference for Measures based on Distance Functions, p.3, 2009. ,
Surface reconstruction from unorganized points, In ACM SIGGRAPH, pp.71-78, 1992. ,
Robust reconstruction of watertight 3D models from non-uniformly sampled point clouds without normal information, EUROGRAPHICS Symposium on Geometry Processing, pp.41-50, 2006. ,
Consolidation of unorganized point clouds for surface reconstruction, ACM Transactions on Graphics, vol.28, issue.2, pp.5-7, 2009. ,
Poisson Surface Reconstruction, EUROGRAPHICS Symposium on Geometry Processing, pp.61-70, 2006. ,
Spectral surface reconstruction from noisy point clouds, EURO- GRAPHICS Symposium on Geometry Processing, pp.11-21, 2004. ,
Robust and efficient surface reconstruction from range data, Computer Graphics Forum, vol.28, issue.8 1, pp.2275-2290, 2009. ,
Estimating surface normals in noisy point cloud data, International Journal of Computational Geometry and Applications, issue.2, 2004. ,
Streaming surface reconstruction using wavelets, Computer Graphics Forum, vol.27, issue.5, pp.1411-1420, 2008. ,
Smoothing of partition of unity implicit surfaces for noise robust surface reconstruction, Computer Graphics Forum, vol.28, pp.5-1339, 2009. ,
Sparse lowdegree implicits with applications to high quality rendering, feature extraction, and smoothing, EUROGRAPHICS Symposium on Geometry Processing, pp.149-158, 2005. ,
Implicit surface modelling as an eigenvalue problem, Machine Learning ICML 2005 (2005), pp.936-939 ,
