Synthesizing Generic Experimental Environments for Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Martin Quinson
Connectez-vous pour contacter l'auteur
Laurent Bobelin
Frédéric Suter
Experiments play an important role in parallel and distributed computing. Simulation is a common experimental technique that relies on abstractions of the tested application and execution environment but offers reproducibility of results and fast exploration of numerous scenarios. This article focuses on setting up the experimental environment of a simulation run. First we analyze the requirements expressed by different research communities. As the existing tools of the literature are too specific, we then propose a more generic experimental environment synthesizer called SIMULACRUM. This tool allows its users to select a model of a currently deployed computing grid or generate a random environment. Then the user can extract a subset of it that fulfills his/her requirements. Finally the user can export the corresponding XML representation.
simulacrum_3PGCIC_2010.pdf (123.35 Ko) Télécharger le fichier
inria-00502839 , version 1 (16-07-2010)
  • HAL Id : inria-00502839 , version 1
Martin Quinson, Laurent Bobelin, Frédéric Suter. Synthesizing Generic Experimental Environments for Simulation. Fifth International Conference on P2P, Parallel, Grid, Cloud and Internet Computing, Nov 2010, Fukuoka, Japan. ⟨inria-00502839⟩
180 Consultations
355 Téléchargements
