New interface
Conference papers
Linking Data and Presentations: from Mapping to Active Transformations
Olivier Beaudoux 1, 2 Arnaud Blouin 2
2 TRISKELL - Reliable and efficient component based software engineering
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : Modern GUI toolkits, and especially RIA ones, propose the concept of binding to dynamically link domain data and their presentations. Bindings are very simple to use for predefined graphical components. However, they remain dependent on the GUI platform, are not as expressive as transformation languages, and require specific coding when designing new graphical components. A solution to such issues is to use active transformations: an active transformation is a transformation that dynamically links source data to target data. Active transformations are however complex to write and/or to process. In this paper, we propose the use of the AcT framework that consists of: a platform-independent mapping language that masks the complexity of active transformations; a graphical mapping editor; and an implementation on the .NET platform.
Document type :
Conference papers
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/inria-00504671
Contributor : Didier Vojtisek Connect in order to contact the contributor
Submitted on : Wednesday, July 21, 2010 - 9:41:22 AM
Last modification on : Wednesday, April 6, 2022 - 3:48:34 PM
Long-term archiving on: : Friday, October 22, 2010 - 4:22:01 PM
File
Beaudoux10b.pdf
Identifiers
  • HAL Id : inria-00504671, version 1
Citation
Olivier Beaudoux, Arnaud Blouin. Linking Data and Presentations: from Mapping to Active Transformations. DocEng'10: Proceedings of the 2010 ACM symposium on Document engineering, 2010, Manchester, United Kingdom. pp.107-110. ⟨inria-00504671⟩
Share
Metrics
Record views
169
Files downloads
53
