New interface
Conference papers
Aspect Model Unweaving
Jacques Klein 1 Jörg Kienzle Brice Morin 2 Jean-Marc Jézéquel 2
2 TRISKELL - Reliable and efficient component based software engineering
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : Since software systems need to be continuously available, their ability to evolve at runtime is a key issue. The emergence of models@runtime, combined with Aspect-Oriented Modeling techniques, is a promising approach to tame the complexity of adaptive systems. However, with no support for aspect unweaving, these approaches are not agile enough in an adaptive system context. In case of small modifications, the adapted model has to be generated by again weaving all the aspects, even those unchanged. This paper shows how aspects can be unwoven, based on a precise traceability metamodel dedicated to aspect model weaving. We analyze traceability models, which describe how aspects were woven into a base, to determine the extent to which an aspect has affected the woven model in order to determine how it can be unwoven. Aspect unweaving is finally performed by applying inverse operations of a sub-sequence of the weaving operations in opposite order.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/inria-00504677
Contributor : Didier Vojtisek Connect in order to contact the contributor
Submitted on : Wednesday, July 21, 2010 - 9:51:08 AM
Last modification on : Friday, February 4, 2022 - 3:25:33 AM
File
Morin09d.pdf
Identifiers
  • HAL Id : inria-00504677, version 1
Citation
Jacques Klein, Jörg Kienzle, Brice Morin, Jean-Marc Jézéquel. Aspect Model Unweaving. ACM/IEEE 12th International Conference on Model Driven Engineering Languages and Systems (MODELS'09), 2009, Denver, Colorado, USA, United States. ⟨inria-00504677⟩
Share
Metrics
Record views
272
Files downloads
3649
