New interface
Journal articles
DROP COST AND WAVELENGTH OPTIMAL TWO-PERIOD GROOMING WITH RATIO 4∗
Abstract : We study grooming for two-period optical networks, a variation of the traffic grooming problem for WDM ring networks introduced by Colbourn, Quattrocchi, and Syrotiuk. In the two-period grooming problem, during the first period of time there is all-to-all uniform traffic among $n$ nodes, each request using $1/C$ of the bandwidth; and during the second period, there is all-to-all uniform traffic only among a subset $V$ of $v$ nodes, each request now being allowed to use $1/C'$ of the bandwidth, where $C' < C$. We determine the minimum drop cost (minimum number of ADMs) for any $n,v$ and $C=4$ and $C' \in \{1,2,3\}$. To do this, we use tools of graph decompositions. Indeed the two-period grooming problem corresponds to minimizing the total number of vertices in a partition of the edges of the complete graph $K_n$ into subgraphs, where each subgraph has at most $C$ edges and where furthermore it contains at most $C'$ edges of the complete graph on $v$ specified vertices. Subject to the condition that the two-period grooming has the least drop cost, the minimum number of wavelengths required is also determined in each case.
Complete list of metadata
Cited literature [30 references]  Display  Hide  Download
https://hal.inria.fr/inria-00505516
Contributor : Jean-Claude Bermond Connect in order to contact the contributor
Submitted on : Friday, July 23, 2010 - 10:26:25 PM
Last modification on : Monday, November 28, 2022 - 4:50:07 PM
Long-term archiving on: : Monday, October 25, 2010 - 12:04:21 PM
File
SIAM74419.pdf
Publisher files allowed on an open archive
Identifiers
  • HAL Id : inria-00505516, version 1
Collections
Citation
Jean-Claude Bermond, Charles J. Colbourn, Lucia Gionfriddo, Gaetano Quattrocchi, Ignasi Sau Valls. DROP COST AND WAVELENGTH OPTIMAL TWO-PERIOD GROOMING WITH RATIO 4∗. SIAM Journal on Discrete Mathematics, 2010, 24 (2), pp.400-419. ⟨inria-00505516⟩
Share
Metrics
Record views
166
Files downloads
97
