Abstract : We consider a novel optic flow estimation algorithm based on a wavelet expansion of the velocity field. In particular, we propose an efficient gradient-based estimation algorithm which naturally encompasses the estimation process into a multiresolution framework while avoiding most of the drawbacks common to this kind of hierarchical methods. We then emphasize that the proposed methodology is well-suited to the practical implementation of high-order regularizations. The powerfulness of the proposed algorithm and regularization schemes are finally assessed by simulation results on challenging image sequence of turbulent fluids.
https://hal.inria.fr/inria-00505780 Contributor : Pierre DérianConnect in order to contact the contributor Submitted on : Wednesday, July 28, 2010 - 12:40:50 PM Last modification on : Wednesday, February 2, 2022 - 3:59:40 PM Long-term archiving on: : Thursday, December 1, 2016 - 5:30:00 PM
