Deluding Image Recognition in SIFT-based CBIR Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thanh-Toan Do
  • Fonction : Auteur
  • PersonId : 870909
Ewa Kijak
Laurent Amsaleg
Content-Based Image Retrieval Systems used in forensics related contexts require very good image recognition capa- bilities. Therefore they often use the SIFT local-feature de- scription scheme as its robustness against a large spectrum of image distortions has been assessed. In contrast, the security of SIFT is still largely unexplored. We show in this paper that it is possible to conceal images from the SIFT-based recognition process by designing very SIFT-specific attacks. The attacks that are successful in deluding the system re- move keypoints and simultaneously forge new keypoints in the images to be concealed. This paper details several strate- gies enforcing image concealment. A copy-detection oriented experimental study using a database of 100,000 real images together with a state-of-art image search system shows these strategies are effective. This is a very serious threat against systems, endangering forensics investigations.
mifor809-do.pdf (376.65 Ko) Télécharger le fichier
inria-00505845 , version 1 (29-03-2011)
  • HAL Id : inria-00505845 , version 1
Thanh-Toan Do, Ewa Kijak, Teddy Furon, Laurent Amsaleg. Deluding Image Recognition in SIFT-based CBIR Systems. ACM Multimedia in Forensics, Security and Intelligence, ACM, Oct 2010, Firenze, Italy. ⟨inria-00505845⟩
495 Consultations
416 Téléchargements
