Towards Robust and Secure Watermarking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents yet another attempt towards robust and secure watermarking. Some recent works have looked at this issue first designing new watermarking schemes with a security oriented point of view, and then evaluating their robustness compared to state-of-the-art but unsecure tech- niques. Our approach is, on contrary, to start from a very robust watermarking technique and to propose changes in order to strengthen its security levels. These changes in- clude the introduction of a security criterion, an embedding process implemented as a maximization of a robustness met- ric under the perceptual and the security constraints, and a watermarking detection seen as a contrario decision test. Our experimentations lead to, once again, a trade-off be- tween security and robustness. The technique is now per- fectly secure against attacks mounted during the second edi- tion of the BOWS challenge, but the price to pay is either a lower robustness against common image processing, either a bigger probability of false alarm.
ACM_MMSec2010.pdf (206.78 Ko) Télécharger le fichier
inria-00505849 , version 1 (29-03-2011)
  • HAL Id : inria-00505849 , version 1
Fuchun Xie, Teddy Furon, Caroline Fontaine. Towards Robust and Secure Watermarking. ACM Multimedia and Security, Sep 2010, Roma, Italy. ⟨inria-00505849⟩
299 Consultations
292 Téléchargements
