Hierarchical Spline Approximation of the Signed Distance Function
We present a method to approximate the signed distance function of a smooth curve or surface by using polynomial splines over hierarchical T-meshes (PHT splines). In particular, we focus on closed parametric curves in the plane and implicitly defined surfaces in space.
Informatique
