Reports
Probabilistic Contracts for Component-based Design
Abstract : We define a probabilistic contract framework for describing and analysing component-based embedded systems, based on the theory of Interactive Markov Chains (IMC). A contract specifies the assumptions a component makes on its context and the guarantees it provides. Probabilistic transitions allow for uncertainty in the component behavior, e.g., to model observed black-box behavior (internal choice) or reliability. An interaction model specifies how components interact. We provide the ingredients for a component-based design flow, including (1) contract satisfaction and refinement, (2) parallel composition of contracts over disjoint, interacting components, and (3) conjunction of contracts describing different requirements over the same component. Compositional design is enabled by congruence of refinement.
Complete list of metadatas
https://hal.inria.fr/inria-00507785
Contributor : Gregor Gössler <>
Submitted on : Tuesday, October 1, 2013 - 8:56:13 AM
Last modification on : Friday, October 25, 2019 - 2:01:10 AM
Document(s) archivé(s) le : Wednesday, October 10, 2012 - 2:25:50 AM
File
RR-7328.pdf
Identifiers
  • HAL Id : inria-00507785, version 2
Collections
Citation
Gregor Gössler, Dana Xu, Alain Girault. Probabilistic Contracts for Component-based Design. [Research Report] RR-7328, INRIA. 2012. ⟨inria-00507785v2⟩
Share
Metrics
Record views
530
Files downloads
332
