Decentralized Approach for Execution of Composite Web Services Using the Chemical Paradigm - Archive ouverte HAL Access content directly
Conference Papers Year : 2010
(1) , (1) , (1)
1
Nowadays, executions of composite Web services are typically conducted by heavyweight centralized engines. A centralized is a potential processing and communication bottleneck as well as a central point of failure, and its cost of deployment is usually too high for a large number of small businesses or end-users. In addition, it presents some weaknesses dealing with privacy issues. These drawbacks, and requirements such as loose coupling, are pushing service infrastructures toward more decentralized and dynamic interaction schemes. In this paper, we propose a decentralized alternative system for the execution of composite Web services based on the chemical analogy. The chemical paradigm provides a high-level execution model that allows executing composite services in a fully decentralized manner. Our architecture is composed by nodes communicating through a shared space containing both control and data flows, allowing to distribute the composition among nodes without the need for any centralized coordination.
Not file
Dates and versions
inria-00508346 , version 1 (03-08-2010)
Identifiers
  • HAL Id : inria-00508346 , version 1
Cite
Héctor Fernandez, Thierry Priol, Cédric Tedeschi. Decentralized Approach for Execution of Composite Web Services Using the Chemical Paradigm. IEEE 8th International Conference on Web Services (ICWS 2010), Jul 2010, Miami, United States. ⟨inria-00508346⟩
113 View
0 Download
Share
