Creating Context-Adaptive Business Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
As the dynamicity of today's business environments keeps increasing, there is a need to continuously adapt business processes in order to respond to the changes in those environments and keep a competitive level. By using complex event processing, we can discover information that is relevant to our organization, which is usually hidden among the data generated in the environment, and use it to adapt the processes accordingly in order to respond to the changing conditions in an optimal way. Unfortunately, the static nature of business process definitions makes it impossible to adapt them at runtime and the redeployment of a modified process is required. By using a component-based approach, we can transform the existing business processes into dynamically bound components, adding the flexibility needed to adapt the processes at runtime. In this paper we present CEVICHE, a framework that combines the strengths of complex event processing and dynamic business process adaptation, which allows to respond to the needs of the rapidly changing environment, and its adaptation language called SBPL, an extension to BPEL which adds flexibility to business processes.
icsoc.pdf (503.73 Ko) Télécharger le fichier
inria-00508988 , version 1 (09-08-2010)
Gabriel Hermosillo, Lionel Seinturier, Laurence Duchien. Creating Context-Adaptive Business Processes. The 8th International Conference on Service Oriented Computing, Dec 2010, San Francisco, California, United States. pp.228-242, ⟨10.1007/978-3-642-17358-5_16⟩. ⟨inria-00508988⟩
262 Consultations
342 Téléchargements
