A Hensel Lifting to Replace Factorization in List-Decoding of Algebraic-Geometric and Reed-Solomon Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2000
Daniel Augot
  • Fonction : Auteur
  • PersonId : 833459
This paper presents an algorithmic improvement to Sudan's list-decoding algorithm for Reed-Solomon codes and its generalization to algebraic-geometric codes from Shokrollahi and Wasserman. Instead of completely factoring the interpolation polynomial over the function field of the curve, we compute sufficiently many coefficients of a Hensel development to reconstruct the functions that correspond to codewords. We prove that these Hensel developments can be found efficiently using Newton's method. We also describe the algorithm in the special case of Reed-Solomon codes.
FinalSub.pdf (219 Ko) Télécharger le fichier
inria-00509339 , version 1 (11-08-2010)
Daniel Augot, Lancelot Pecquet. A Hensel Lifting to Replace Factorization in List-Decoding of Algebraic-Geometric and Reed-Solomon Codes. IEEE Transactions on Information Theory, 2000, 46 (7), pp.2605 - 2614. ⟨10.1109/18.887868⟩. ⟨inria-00509339⟩
Collections
INRIA INRIA2
145 Consultations
247 Téléchargements
