The transformation, of Poisson, binomial and negativebinomial data, Biometrika, vol.35, issue.34, p.246254, 1948. ,
Regularization parameter selection methods for ill-posed Poisson maximum likelihood estimation, Inverse Problems, vol.25, issue.9 ,
DOI : 10.1088/0266-5611/25/9/095005
Overcomplete Discrete Wavelet Transforms With Rational Dilation Factors, IEEE Transactions on Signal Processing, vol.57, issue.1, p.131145, 2009. ,
DOI : 10.1109/TSP.2008.2007097
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.218.2974
A Fast Iterative Shrinkage-Thresholding Algorithm for Linear Inverse Problems, SIAM Journal on Imaging Sciences, vol.2, issue.1, 2009. ,
DOI : 10.1137/080716542
Convex Optimization, 2004. ,
Fast Discrete Curvelet Transforms, Multiscale Modeling & Simulation, vol.5, issue.3, p.861899, 2006. ,
DOI : 10.1137/05064182X
R??gularit?? et parcimonie pour les probl??mes inverses en imagerie. Algorithmes et comparaisons, Traitement du signal, vol.27, issue.2 ,
DOI : 10.3166/ts.27.189-219
URL : https://hal.inria.fr/inria-00503050/document
Complex wavelet regularization for solving inverse problems in remote sensing, 2009 IEEE International Geoscience and Remote Sensing Symposium, 2009. ,
DOI : 10.1109/IGARSS.2009.5417865
URL : https://hal.archives-ouvertes.fr/inria-00417708
An algorithm for total variation minimization and applications, J. Math. Imaging Vis, vol.20, issue.12, p.8997, 2004. ,
Wavelet-based restoration methods: application to 3D confocal microscopy images, Wavelets XII, 2007. ,
DOI : 10.1117/12.731438
URL : https://hal.archives-ouvertes.fr/hal-00733457
A forwardbackward algorithm for image restoration with sparse representations ,
URL : https://hal.archives-ouvertes.fr/hal-00017658
Image analysis using a dualtree m-band wavelet transform, Image Processing IEEE Transactions on, vol.15, issue.8, p.23972412, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01330599
Nested Iterative Algorithms for Convex Constrained Image Recovery Problems, SIAM Journal on Imaging Sciences, vol.2, issue.2, p.730762, 2009. ,
DOI : 10.1137/080727749
URL : https://hal.archives-ouvertes.fr/hal-00621932
A proximal decomposition method for solving convex variational inverse problems, Inverse Problems, vol.24, issue.6, 2008. ,
DOI : 10.1088/0266-5611/24/6/065014
URL : https://hal.archives-ouvertes.fr/hal-00692901
Signal recovery by proximal forwardbackward splitting, Multiscale Modeling & Simulation, vol.4, issue.4, p.11681200, 2005. ,
DOI : 10.1137/050626090
URL : https://hal.archives-ouvertes.fr/hal-00017649
Richardson???Lucy algorithm with total variation regularization for 3D confocal microscope deconvolution, Microscopy Research and Technique, vol.59, issue.4, p.260266, 2006. ,
DOI : 10.1002/jemt.20294
A Proximal Iteration for Deconvolving Poisson Noisy Images Using Sparse Representations, IEEE Transactions on Image Processing, vol.18, issue.2, p.310321, 2009. ,
DOI : 10.1109/TIP.2008.2008223
Analysis versus synthesis in signal priors, Inverse Problems, vol.23, issue.3, p.947968, 2007. ,
DOI : 10.1088/0266-5611/23/3/007
Applications of lagrangian-based alternating direction methods and connections to split bregman, UCLA Cam Report, 2009. ,
Restoration of Poissonian Images Using Alternating Direction Optimization, IEEE Transactions on Image Processing, vol.19, issue.12, 2010. ,
DOI : 10.1109/TIP.2010.2053941
Numerical Methods for Nonlinear variation al Problems ,
Generalized Cross-Validation as a Method for Choosing a Good Ridge Parameter, Technometrics, vol.5, issue.2, pp.215-223, 1979. ,
DOI : 10.1080/03610927508827223
On the analysis of fluorescence decay kinetics by the method of least-squares, Analytical Biochemistry, vol.59, issue.2, pp.583-598, 1974. ,
DOI : 10.1016/0003-2697(74)90312-1
An iterative technique for rectication of observed distributions ,
A Wavelet Tour of Signal Processing, Third Edition: The Sparse Way, 2008. ,
Memoir on inventing the confocal scanning microscope, Scanning, vol.10, issue.4, p.128138, 1988. ,
DOI : 10.1002/sca.4950100403
Gradient methods for minimizing composite objective function . CORE Discussion Paper, 2007. ,
Solving Constrained Total-variation Image Restoration and Reconstruction Problems via Alternating Direction Methods, SIAM Journal on Scientific Computing, vol.32, issue.5 ,
DOI : 10.1137/090774823
A Restoration Method for Confocal Microscopy Using Complex Wavelet Transform, Proceedings. (ICASSP '05). IEEE International Conference on Acoustics, Speech, and Signal Processing, 2005., 2005. ,
DOI : 10.1109/ICASSP.2005.1415481
Hybrid regularization for data restoration in the presence of Poisson noise, 17th European Signal Processing Conference, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00621941
Monte-Carlo Sure: A Black-Box Optimization of Regularization Parameters for General Denoising Algorithms, IEEE Transactions on Image Processing, vol.17, issue.9 ,
DOI : 10.1109/TIP.2008.2001404
Deconvolution of 3d uorescence micrographs with automatic risk minimization, Biomedical Imaging: From Nano to Macro ISBI 2008. 5th IEEE International Symposium on, p.732735, 2008. ,
Bayesian-Based Iterative Method of Image Restoration*, Journal of the Optical Society of America, vol.62, issue.1, p.5559, 1972. ,
DOI : 10.1364/JOSA.62.000055
Nonlinear total variation based noise removal algorithms, Physica D: Nonlinear Phenomena, vol.60, issue.1-4, p.259268, 1992. ,
DOI : 10.1016/0167-2789(92)90242-F
The dual-tree complex wavelet transform, IEEE Signal Processing Magazine, vol.22, issue.6, p.123151, 2005. ,
DOI : 10.1109/MSP.2005.1550194
Signal restoration with overcomplete wavelet transforms: comparison of analysis and synthesis priors, Wavelets XIII, 2009. ,
DOI : 10.1117/12.826663
Deblurring Poissonian images by split Bregman techniques, Journal of Visual Communication and Image Representation, vol.21, issue.3, p.193199, 2010. ,
DOI : 10.1016/j.jvcir.2009.10.006
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.564.8327
Three-dimensional image formation in confocal microscopy, Journal of Microscopy, vol.1, issue.2, p.179194, 1990. ,
DOI : 10.1111/j.1365-2818.1990.tb04774.x
Image Restoration in Fluorescence Microscopy, 1999. ,
The inuence of the regularization parameter and the rst estimate on the performance of tikhonov regularized non-linear image restoration algorithms, Journal of Microscopy, vol.13, p.6375, 2000. ,
A quantitative comparison of image restoration methods for confocal microscopy, Journal of Microscopy, vol.185, issue.3, p.354365, 1997. ,
DOI : 10.1046/j.1365-2818.1997.d01-629.x
Ecient gradient projection methods for edge-preserving removal of poisson noise, Inverse Problems, vol.25, issue.4, 2009. ,
