Efficient rendering of radiosity using texture and bicubic interpolation, 1997 Symposium on Interactive 3D Graphics, pp.71-74, 1997. ,
Improving Radiosity Solutions Through the Use of Analytically Determined Form-Factors, Computer Graphics (ACM SIGGRAPH '89 Proceedings ), Volume, pp.325-334, 1989. ,
A Progressive Refinement Approach to Fast Radiosity Image Generation, Computer Graphics (ACM SIGGRAPH '88 Proceedings ), Volume, pp.75-84, 1988. ,
Radiosity and Realistic Image Synthesis, 1993. ,
Accurate Visibility and Meshing Calculations for Hierarchical Radiosity, Rendering Techniques '96 (Proceedings of the Seventh Eurographics Workshop on Render- Texture-Based Visibility for Efficient Lighting Simulation ¡ 33, 1996. ,
Fast and accurate hierarchical radiosity using global visibility, ACM Transactions on Graphics, vol.18, issue.2, pp.128-170, 1999. ,
A Model of Visual Adaptation for Realistic Image Synthesis, Computer Graphics Proceedings, Annual Conference SeriesACM SIGGRAPH '96 Proceedings) (1996), pp.249-258, 1996. ,
Textures and Radiosity: Controlling Emission and Reflection with Texture Maps, Computer Graphics Proceedings, Annual Conference SeriesACM SIGGRAPH '94 Proceedings), pp.51-58, 1994. ,
Perceptually driven radiosity, Computer Graphics Forum, vol.162, pp.119-128, 1997. ,
Modelling the Interaction of Light Between Diffuse Surfaces, Computer Graphics (ACM SIGGRAPH '84 Proceedings), Volume, pp.212-222, 1984. ,
Controlling memory consumption of hierarchical radiosity with clustering, Graphics Interface, pp.58-65, 1999. ,
Shaft culling for efficient ray-traced radiosity, Eurographics Workshop on Rendering, pp.122-138, 1991. ,
A Rapid Hierarchical Radiosity Algorithm, Computer Graphics (ACM SIGGRAPH '91 Proceedings), Volume, pp.197-206, 1991. ,
Simulating soft shadows with graphics hardware, CS See also the Sketch in Siggraph'96 visual proceedings, 1997. ,
Bounds and error estimates for radiosity, Proceedings of SIGGRAPH '94 Computer Graphics Proceedings, Annual Conference Series, pp.67-74, 1994. ,
Discontinuity Meshing for Accurate Radiosity, IEEE Computer Graphics and Applications, vol.12, issue.6, pp.25-39, 1992. ,
A two-pass hardware-based method for hierarchical radiosity, Proc. Eurographics '98), pp.159-164, 1998. ,
Texture Mapping as an Alternative for Meshing During Walkthrough Animation, Fifth Eurographics Workshop on Rendering, pp.375-388, 1994. ,
OpenGL Programming Guide, 1993. ,
Eurographics 98 State of the Art Reports, Chapter State of the Art in Perceptually-Driven Radiosity Eurographics Association, pp.89-104, 1998. ,
Rendering antialiased shadows with depth maps, Computer Graphics (SIGGRAPH '87 Proceedings), Volume, pp.283-291, 1987. ,
Wavelet Projections for Radiosity, Fourth Eurographics Workshop on Rendering, pp.105-114, 1993. ,
Feature-Based Control of Visibility Error: A Multiresolution Clustering Algorithm for Global Illumination, Computer Graphics Proceedings, Annual Conference SeriesACM SIGGRAPH '95 Proceedings), pp.145-152, 1995. ,
Radiosity and Global Illumination, 1994. ,
A Clustering Algorithm for Radiosity in Complex Environments, Computer Graphics Proceedings, Annual Conference Series, 1994 (ACM SIGGRAPH '94 Proceedings), pp.435-442, 1994. ,
Automatic calculation of soft shadow textures for fast, high quality radiosity, Eds., Rendering Techniques'98 (Proceedings of Eurographics Rendering Workshop '98), pp.199-210, 1998. ,
Fast calculation of soft shadow textures using convolution, Computer Graphics (ACM SIGGRAPH '98 Proceedings), pp.321-332, 1998. ,
Perceiving spatial relationships in computer-generated images, IEEE Computer Graphics and Applications, vol.12, issue.3, pp.44-58, 1992. ,
