Evaluating signs of determinants using single-precision arithmetic, Algorithmica, vol.37, issue.6, 1994. ,
DOI : 10.1007/BF02522822
URL : https://hal.archives-ouvertes.fr/inria-00074367
Triangulating a simple polygon in linear time, Discrete & Computational Geometry, vol.15, issue.3, pp.485-524, 1991. ,
DOI : 10.1007/BF02574703
An optimal algorithm for intersecting line segments in the plane, Journal of the ACM, vol.39, issue.1, pp.1-54, 1992. ,
DOI : 10.1145/147508.147511
An optimal algorithm for Monte Carlo estimation (extended abstract), 36th Annual Symposium on Foundations of Computer Science, pp.142-149, 1995. ,
Computational geometry by example, 1996. ,
A random polynomial time algorithm for approximating the volume of convex bodies, ACM STOC, pp.375-381, 1989. ,
Intersection volumes and surface areas of cylinders for geometrical modelling and tolerancing, Computer-Aided Design, vol.26, issue.1, pp.29-45, 1994. ,
DOI : 10.1016/0010-4485(94)90005-1
Robustness in geometric modeling ??? Tolerance-based methods, Computational Geometry ? Methods, Algorithms and Applications: Proc. Internat. Workshop Comput. Geom. CG '91, pp.85-101, 1991. ,
DOI : 10.1007/3-540-54891-2_7
Overlaying simply connected planar subdivisions in linear time, Proceedings of the eleventh annual symposium on Computational geometry , SCG '95, 1995. ,
DOI : 10.1145/220279.220292
Simplified linear-time jordan sorting and polygon clipping, Information Processing Letters, vol.35, issue.2, p.35, 1990. ,
DOI : 10.1016/0020-0190(90)90111-A
Epsilon geometry: building robust algorithms from imprecise computations, Proc. 5th Annu. ACM Sympos, pp.208-217, 1989. ,
Assembly sequencing with toleranced parts, Computer Aided Design, vol.29, issue.2, 1997. ,
Polytope volume computation, Mathematics of Computation, vol.57, issue.195, pp.259-71, 1991. ,
DOI : 10.1090/S0025-5718-1991-1079024-2
Tolerances in product modelling, Informatik, Informationen Reporte, issue.5, pp.4-52, 1991. ,
Randomized Algorithms, 1995. ,
Plane-sweep algorithms for intersecting geometric figures, Communications of the ACM, vol.25, issue.10, p.25, 1982. ,
DOI : 10.1145/358656.358681
Computational Geometry: An Introduction, 1985. ,
DOI : 10.1007/978-1-4612-1098-6
Review of dimensioning and tolerancing: representation and processing, Computer-Aided Design, vol.23, issue.7, pp.466-83, 1991. ,
DOI : 10.1016/0010-4485(91)90045-X
Epsilon geometry: building robust algorithms from imprecise computations, Proceedings of the fifth annual symposium on Computational geometry , SCG '89, 1991. ,
DOI : 10.1145/73833.73857
Robust adaptive floating-point geometric predicates, Proceedings of the twelfth annual symposium on Computational geometry , SCG '96, pp.141-150, 1996. ,
DOI : 10.1145/237218.237337
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.53.6004
Recent efforts in mathematization of asme/ansi y14.5m standard. In 3 rd CIRP seminars on computer aided tolerancing, 1993. ,
Creation and evolution of the asme y14.5.1 standard, Manufacturing Review, vol.7, issue.1, 1994. ,
A scheme to represent features, dimensions, and tolerances in geometric modeling, Journal of Manufacturing Systems, vol.10, issue.3, pp.233-273, 1991. ,
DOI : 10.1016/0278-6125(91)90036-2
