Combinatorial properties of one-dimensional arrangements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Experimental Mathematics Année : 1997
Arrangements are an omni-present topic in computational geometry, since many problems in computer graphics and robotics reduce to the study of such sets. Motivated by two problems from these areas —more precisely from ray-tracing and assembly planning, we study in this paper the combinatorial structure of arrangements of segments on a line and of cones on a circle. We show that the numbers of such arrangements are respectively 1.3.5 . . . (2n−1) and (2n)!/n!, that the probabilities for the ith vertex of a random arrangement to be a beginning point are 1−(i−1)/(2n−1) and 1/2, and that the average numbers of segments or cones the ith vertex is contained in are (1−i)(i−2n)/(2n−1) and (n − 1)/2. In addition to providing results for the analysis of the the ray tracing related and assembly sequencing problems, the constructions used to prove these results provide sampling schemes for generating random inputs usable to test and validate the correctness of programs manipulating arrangements. Along with the derivation of these identities, we also point out connections between arrangements, sub-diagonal random walks and the ballot problem, as well as other integer sequences.
arrangements1d.pdf (206.02 Ko) Télécharger le fichier
inria-00509987 , version 1 (17-08-2010)
  • HAL Id : inria-00509987 , version 1
Frédéric Cazals. Combinatorial properties of one-dimensional arrangements. Experimental Mathematics, 1997, 6 (1). ⟨inria-00509987⟩
68 Consultations
195 Téléchargements
