Abstract : In this paper, we explore the set of testable properties within the Safety-Progress classification where testability means to establish by testing that a relation, between the tested system and the property under scrutiny, holds. We characterize testable properties wrt. several relations of interest. For each relation, we give a su cient condition for a property to be testable. Then, we study and delineate, for each Safety-Progress class, the subset of testable properties and their corresponding test oracle producing verdicts for the possible test executions. Finally, we address automatic test generation for the proposed framework.
