Street Generation for City Modelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
In this paper, we present a complete solution for automatically retrieving the street graph of an urban model. Given a set of 2-5D polygons representing the buildings footprints and their heights, the algorithm constructs a graph that represent the street network (a node for a crossing, an edge a street, each associated with a set of surrounding buildings) along with geometric information such as the width of the streets. We demonstrate how this graph can be used to analyze the city structure and give an example of its use with an automatic geometric modeler for city streets.
article.pdf (506.56 Ko) Télécharger le fichier
Nantes.ppt (935.5 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00510041 , version 1 (17-08-2010)
  • HAL Id : inria-00510041 , version 1
Xavier Décoret, François X. Sillion. Street Generation for City Modelling. Architectural and Urban Ambient Environment, 2002, Nantes, France. ⟨inria-00510041⟩
229 Consultations
163 Téléchargements
