Point-Based Impostors for Real-Time Visualization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Michael Wimmer
  • Fonction : Auteur
Peter Wonka
  • Fonction : Auteur
We present a new data structure for encoding the appearance of a ge-ometric model as seen from a viewing region (view cell). This representation can be used in interactive or real-time visualization applications to replace a complex model by an impostor, maintaining high quality rendering while cutting down rendering time. Our approach relies on an object-space sampled representation similar to a point cloud or a layered depth image, but introduces two fundamental additions to previous techniques. First, the sampling rate is controlled to pro-vide sufficient density across all possible viewing conditions from the specified view cell. Second, a correct, antialiased representation of the plenoptic function is computed using Monte Carlo integration. Our system therefore achieves high quality rendering using a simple representation with bounded complexity. We demonstrate the method for an application in urban visualization.
wimmer_egrw2001.pdf (2.24 Mo) Télécharger le fichier
Format : Figure, Image
inria-00510050 , version 1 (17-08-2010)
  • HAL Id : inria-00510050 , version 1
Michael Wimmer, Peter Wonka, François X. Sillion. Point-Based Impostors for Real-Time Visualization. EuroGraphics Workshop on Rendering, 2001, Londres, United Kingdom. ⟨inria-00510050⟩
80 Consultations
262 Téléchargements
