Adaptive Simulation of Soft Bodies in Real-Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
This paper presents an adaptive technique to animate deformable bodies in real-time. In contrast to most previous work, we introduce a multi-resolution model that locally refines or simplifies the simulated object over time in order to optimize the computational effort. We use the mixed Finite-Volume/Finite-Element method to derive fast, local discrete differential operators over irregular grids with tight error bounds. The linear elasticity equations can be simulated using an arbitrary non-nested hierarchy of volumetric meshes, allowing the computation load to be automatically concentrated where and when needed. Real-time simulation, with a guaranteed frame rate, can be achieved as demonstrated through a series of examples on our video.
Mots clés
adaptiveFE.pdf (289.72 Ko) Télécharger le fichier
adaptiveFE.ppt (1.59 Mo) Télécharger le fichier
hybrid.avi (11.42 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00510054 , version 1 (17-08-2010)
  • HAL Id : inria-00510054 , version 1
Gilles Debunne, Mathieu Desbrun, Marie-Paule Cani, Alan H. Barr. Adaptive Simulation of Soft Bodies in Real-Time. Computer Animation 2000, 2000, Philadelphie, United States. pp.133-144. ⟨inria-00510054⟩
270 Consultations
393 Téléchargements
