New interface
Conference papers
Simulating Landslides for Natural Disaster Prevention
Abstract : The simulation of landslide hazards is a key point in the prevention of natural disasters, since it enables to compute risk maps and helps to design protection works. We present a 3D simulator that handles both rock-falls and mud-flows. The terrain model is built from geological and vegetation maps, superimposed on a DEM. Since the exact elevation of the terrain is unknown at the rock's scale, the simulator uses a series of stochastic simulations, where low scale geometry is slightly randomized at each impact, to compute an envelop of risk areas. Computations are optimized using an implicit formulation of surfaces and a space-time adaptive algorithm for animating the particle system that represents the mud flow.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/inria-00510087
Contributor : Team Evasion Connect in order to contact the contributor
Submitted on : Tuesday, August 17, 2010 - 3:14:30 PM
Last modification on : Friday, November 18, 2022 - 9:24:06 AM
Long-term archiving on: : Tuesday, October 23, 2012 - 12:25:22 PM
landslides.pdf
Identifiers
  • HAL Id : inria-00510087, version 1
Citation
Jean-Dominique Gascuel, Marie-Paule Cani, Mathieu Desbrun, Eric M. Leroy, Carola Mirgon. Simulating Landslides for Natural Disaster Prevention. 9th Eurographics Workshop on Computer Animation and Simulation (EGCAS'98), 1998, Lisbonne, Portugal. ⟨inria-00510087⟩
Share
Metrics
Record views
238
Files downloads
737
