Progressive Surface Reconstruction from Images Using a Local Prior - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper introduces a new method for surface reconstruction from multiple calibrated images. The primary contribution of this work is the notion of local prior to combine the flexibility of the carving approach with the accuracy of graph-cut optimization. A progressive refinement scheme is used to recover the topology and reason the visibility of the object. Within each voxel, a detailed surface patch is optimally reconstructed using a graph-cut method. The advantage of this technique is its ability to handle complex shape similarly to level sets while enjoying a higher precision. Compared to carving techniques, the addressed problem is well-posed, and the produced surface does not suffer from aliasing. In addition, our approach seamlessly handles complete and partial reconstructions: If the scene is only partially visible, the process naturally produces an open surface; otherwise, if the scene is fully visible, it creates a complete shape. These properties are demonstrated on real image sequences.
Zeng_05_Local_Prior.pdf (1.42 Mo) Télécharger le fichier
Format : Figure, Image
inria-00510155 , version 1 (13-10-2010)
  • HAL Id : inria-00510155 , version 1
Gang Zeng, Sylvain Paris, Long Quan, François X. Sillion. Progressive Surface Reconstruction from Images Using a Local Prior. International Conference on Computer Vision, 2005, Beijing, China. ⟨inria-00510155⟩
562 Consultations
403 Téléchargements
